BGP issues
Jul 29th, 2009
Multihomed router located at HQ has multiple 3 paths to the public internet(3 ISP).
1.Please do clarify if the service providers advertise the publicly routed IP block to the public network concurrently or only one does while others occupy redundancy state ? taking loop effect into consideration.
2.Does AS-Prepend superceeds,Weight attribute to influence path to the internet ?
3.What happens when looking glass tool shows a blank result for an enterprise AS no agreed to be advertised by the 3 service providers.
4.What is the best way to troubleshoot,narrow-down and detect where issue lies when BGP internet link ?
5.A service provider claims a problem to be from NIXP.Can you shed more light on this sort of incident?
I can confidently handle layer-1 and few of layer-2 issues.
I really need useful tips on route advertisement on the public internet.
Thank You for your usual apt response..
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Wed, 07/29/2009 - 09:15
  • Hall of Fame,
    Founding Member
Hello Femi,
real BGP multihoming requires that the enterprise has its own public IP address block and its own BGP AS number; both can be asked to the regional internet registry:
ARIN www.arin.net for North America
RIPE for Europe www.ripe.net
APNIC for Asia pacific and so on.
Without your own AS number and your own public IP address block a combination of BGP and NAT can be used to implement redundancy.
BGP builds loop free paths by examining the AS path attribute (loop avoidance rule says discard routes whose AS path already contains my AS number).
2)
Weight can be used on local node (it is a Cisco feature) to give preference to outbound path to the internet.
AS path prepending is a way to try to influence the return path from the internet to your IP prefixes.
3)
Before getting your own AS number and IP address block it is likely the enterprise is using an IP address block from one provider.
4)
traceroute made from different internet points can help
you can find a list of looking glasses allowing traceroutes in
www.traceroute.org
BGP commands that can help are:
sh ip bgp summary
sh ip bgp neighbors
sh ip bgp neigh x.x.x.x received-routes
sh ip bgp neigh x.x.x.x advertised-routes
5)
The service provider is likely connecting to the NIXP. However, there can be different policies in BGP exchange of routes at the NIXP, and of course also a NIXP can have technical troubles like a lan switch fault for example or a misbeahiving device that corrupts other devices ARP table (just to make two examples)
Hope to help
Giuseppe
Istvan_Rabai Wed, 07/29/2009 - 22:28
  • Gold, 750 points or more
Just to make an addition to Question 2:
BGP path selection based on weight has precedence over selecting paths based on AS-Path length.
To be specific, here is the exact sequence of decision making (only the beginning of the whole process):
1. Choose the prefix with the highest weight.
2. If weights are equal, choose the highest local preference.
3. If local preferences are equal, select the prefix originated by the local router.
4. Select the prefix with the shortest AS-path length.
5. If AS-path lengths are equal, select the prefix with the lowest origin code
6. If the origin codes are the same, select the prefix with the lowest MED value.
...etc.
As you can see, decision making using weights is earlier in the sequence.
But, as Giuseppe says, be aware, that weight is Cisco specific, and you won't find it in other vendors' BGP implementations.
Cheers:
Istvan
femiayegbusi Thu, 07/30/2009 - 03:20
Can I conclude that the 3 service providers advertise the publicly routed IP blocks at the same time and I am left with an option to use the Bgp attributes (weight & As prepend path,etc)to influence enterprise internet outbound path and the return path from the internet.
For example:ISP A,can route me to the internet using weight attribute while ISP B,handles return path adopting
AS-Path prepend feature.
I stand corrected on above phrase,
Thanks to the DUO for your apt response.I appreciate immensely.
Regards...
Giuseppe Larosa Thu, 07/30/2009 - 04:22
  • Hall of Fame,
    Founding Member
Hello Femi,
your understanding is correct you can choice ISPA as your preferred outgoing path using weight until you have a single border router multihomed (weight is not sent to anyone it is local on device).
If in the future you will have multiple BGP routers you will need to use local preference attribute.
You can try to influence what is your preferred inbound path by prepending the advertisements sent to the other paths/ISP.
If you want to have ISPB as preferred you need to make worse= prepend your AS number towards ISPA and ISPC
It is in both cases you that perform actions not your providers unless there are specific agreements.
Hope to help
Giuseppe
femiayegbusi Thu, 07/30/2009 - 04:51
It is most preffered to have 3 ISP from maximum uptime point of view...But what do you mean by the caption below.Please make it more explicit......
''If you want to have ISPB as preferred you need to make worse= prepend your AS number towards ISPA and ISPC''
Thanks...
Giuseppe Larosa Thu, 07/30/2009 - 05:28
  • Hall of Fame,
    Founding Member
Hello Femi,
you use prepending on your side to make the AS path attribute to looks like longer then real.
So AS path prepending is to be used on the links you want to be the less preferred return paths.
You send not prepended BGP advertisements towards the ISP you would like to use as preferred return path
Hope to help
Giuseppe
