SolutionsConcept Thu, 07/30/2009 - 18:48
Hi when I go in termial with telent and use trace ccommande UC520 see internet correctly. But when I go in CCA 2.0 he dosent accept registar SIP I have error no internet.
How solve this problem ?
Marcos Hernandez Fri, 07/31/2009 - 06:10
  • Blue, 1500 points or more
Have you checked your DNS settings? Can you do a traceroute from the console using names? e.g. "traceroute www.google.com"
Marcos
SolutionsConcept Fri, 07/31/2009 - 17:51
Yes all system internet work I'm connected to 3 router. All see correctly internet. Router are connected to Switch and UC520 same. But only UC520 doesn't see internet. And if I connect directly routeur to WAN ou Expansion port same problem SIP doesn't see internet. and IP 192.168.10.1 (data) no see internet.
Marcos Hernandez Mon, 08/03/2009 - 16:39
I am not sure I completely understand this setup. I would advise that you contact TAC so they can help you figure out the problem.
Marcos
