Using syslog with VRF
Jul 29th, 2009
I've got a cisco 3825 and I would like to send syslog messages to a server located into a VRF with a loopback1 as source-interface.
The problem is when I want to set up the loopback1 as source-interface I got this error message :
"Interface Loopback1 is not in the global table"
How can I set up this loopback1 as the source-interface even if this one is into a VRF?.
Best Regards
Nicolas
Giuseppe Larosa Wed, 07/29/2009 - 09:18
  • Hall of Fame,
    Founding Member
Hello Nicolas,
check if the command has a vrf option before specifying the server ip address.
if there is specify the VRF name where the loop1 is placed and then the loop1 name
Hope to help
Giuseppe
Giuseppe Larosa Wed, 07/29/2009 - 10:15
  • Hall of Fame,
    Founding Member
Hello Laurent,
I was meaning something like:
logging host 10.0.150.63 vrf
vpn1
like in the document you have linked
Edit:
you're right the command above allows to specify a destination for syslog messages in a VRF context, OP asked about choicing a source.
Hope to help
Giuseppe
