WCCP - 6500 CPU
Answered Question
Jul 29th, 2009
I have redundant 6500 Sup720's in my core and a 4.1.3 Core WAE.
I'm using generic-gre as my return method and have the tunnel interfaces configured on my 6500's.
Everything works fine, but anytime I make a change such as adding ip wccp 61 redirect in to a new VLAN interface - my CPU jumps up to ~100% for about 5 minutes before calming down. It looks like it is always the FM CORE process. I do have a pretty lengthy WCCP Redirect list applied for both 61 and 62.
Should this short term jump in CPU be exptected?
Correct Answer by Jerry Ye about 7 years 11 months ago
Hi Michael,
What IOS version are you using? It is quite possible you are hitting this bug - CSCsh56941.
HTH,
jerry
Overall Rating: 5 (1 ratings)
Correct Answer
Jerry Ye Wed, 07/29/2009 - 14:27
  • Cisco Employee,
Hi Michael,
HTH,
jerry
robertsmichael Thu, 07/30/2009 - 07:24
I'm running 12.2(18) so this is more than likely the issue.
Thanks.
Jerry Ye Thu, 07/30/2009 - 07:27
  • Cisco Employee,
Hi Michael,
I am not sure you are ready to upgrade, this issue is fixed in SXI according from the bug detail.
HTH,
jerry
