Agents Personal Recording before answering call.
Jul 29th, 2009
Can someone tell me if this is possible? I have a supervisor who wants his agents to record a personal greeting to be played before receiving a call from the queue. The way the agents only needs to say can I help you. Instead of the usually greeting, (company name, agents name how can I help you).
Jonathan Schulenberg Wed, 07/29/2009 - 12:49
  • Cisco Designated VIP,
    2017 IP Telephony
Are you using CCX or CCE?
Assuming CCX: No. This enhancement request is on the product road map; however, it has not been execute committed last I asked.
hari.kanan Wed, 07/29/2009 - 21:11
this is normally called as Agent Greeting. this is possible using both IPIVR as well as CVP.
search in the forums for more information.
asafayan Fri, 07/31/2009 - 13:46
I have access to Cisco Live and I'm listening to the Cisco Unified Contact Center Express Scripting by Chris Yeo, Product Manager - Cisco.
In slide 23 he specifically cites an example of setting the Connect propert to "no" in the Select Resource step. By doing this you provide a delay of the transfer to an agent and he states this can be used for playing the agent's personal greeting prior to routing the call to the agent. Unfortunately, he doesn't give a script example of this.
I'm hoping the seasoned scripting engineers that monitor this site may have some insight into how this can be done with an example script.
