Amit Singh Wed, 07/29/2009 - 23:26
  • Cisco Employee,
You have two different ISP's terminating on the router or a single ISP with 2 link. What protocol is being used with the ISP's.
-amit singh
Jigar Dave Tue, 08/04/2009 - 01:41
Hi Saquib,
there is a design loop-pole in scenario because you ahve terminated links of two different ISP on one single router. so if some technical problem occures on that router, your whole site is isolated. (incase of port not working, earthing issue, router booting issue) so you need to have ISP links on different routers, you can use R1 to terminate ISP1 link and R2 to terminate ISP2 link. this would be perfect design scenerio.
J K D
