QOS Problem
Jul 30th, 2009
Dear Buddy,
i'm doing a testing with "auto qos".I have cisco ISR routers of series 2821 and 2811.We are using 512/128/64 leased line link for connectivity with routers in remote location.Voice is already implemented on FXO or E1.
Here we are using "auto discovery qos trust" and "auto qos" commands to activate qos at directly connected serial ports.After using "auto discovery qos trust", "auto qos" command takes some to activate but some times link will be lost from remote side.
At that time i have to disable "auto discovery qos trust" and "auto qos" commands.
I want to know why it is happening and how i can overcome?
Siddhartha
gogasca Sun, 08/02/2009 - 10:45
Hi Siddartha
I recommend you opening a TAC, including show tech.
This iwll require more analysis
