FXO test in Remote Location.
Answered Question
Jul 30th, 2009
Hi...
I have four routers in a remote location used as an FXO gatway, and its communicating with CM6.1 using MGCP.
Is there a way to check whether the FXO line is connected, and that there is a dial tone available on this port or not?
Correct Answer by Paolo Bevilacqua about 7 years 7 months ago
Correct, there is no way to know without calling. Remember, CO sends dialtone only when phone goes off-hook.
Thanks for the nice rating and good luck.
Correct Answer by Nicholas Matthews about 7 years 7 months ago
If you do a 'debug vpm signal' and you see this: htsp_process_event: [2/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_proc
That means there isn't a device giving dial tone normally.
If it's good, you'll see things like CALL_PROC, VOICE_CUTOVER, etc.
hth,
nick
Correct Answer by Paolo Bevilacqua about 7 years 8 months ago
Take "debug vpm signal" with "term mon" when making a call, if there is no current loop it will be easy to tell, as it generates an error.
The other obvious test is to call into that line and observe the same debug for incoming ring.
Overall Rating: 5 (6 ratings)
Correct Answer
Paolo Bevilacqua Fri, 07/31/2009 - 03:36
  • Hall of Fame,
    Founding Member
adham_tahoun Sat, 08/01/2009 - 09:09
Thanks..
But what kind of debug message should I expect when making a call to outside - outgoing direction- ?
And does that mean there is no way to check whether the dial tone is available and the connection is UP without calling in or out to that port? It will be easier than calling 10 lines.
Thanks again.
Correct Answer
Nicholas Matthews Sat, 08/01/2009 - 10:00
  • Red, 2250 points or more
hth,
nick
Correct Answer
Paolo Bevilacqua Sat, 08/01/2009 - 12:22
  • Hall of Fame,
    Founding Member
adham_tahoun Sat, 08/01/2009 - 12:41
mmm, it will go like this.
The router to imitate call initiation, it off-hook the FXO port, detect the signal, and give a message that a dial-tone has been detected.
Anyways, Thanks for both of you for your time, my problem has been solved. :)
