How to reset default factory command on ASA ,Router and Switch
Jul 30th, 2009
Dear All,
I would like to ask you about how to reset default factory on ASA,Router and Switch ( i mean it similar wr erase but if we do command wr erase all the command is gone, so i would like to original command on product.
Best Regards,
Rechard
hobbe Thu, 07/30/2009 - 04:44
  • Gold, 750 points or more
ASA
conf t
configure factory-default
Router: I dont know if there is such a command.
might be depending on model of router and software version.
so wr er and then reload is the closest I know off
Switch:
I do not know of such a command, might exist depending on model and software version
so wr er and then do a reload is the closest I know of.
Good luck
