CAD Agent status - UCCX 5.0
Jul 30th, 2009
Is it possible to get the Ready or Not Ready status of the agent in CAD ?
I have a line of a script which attempts to get the value of the status:
agentState = Get Reporting Statistic (State[agent]) from Resource IPCC Express)
if (agentState == "Ready") Then...
When I do a reactive Debug, the value returned for agentstate is a string with "invalid" value.
I am not sure how to get the value of the CAD agent status
Any help appreciated.
Paul
Jonathan Schulenberg Thu, 07/30/2009 - 06:30
  • Cisco Designated VIP,
    2017 IP Telephony
You need to have a valid username in the Row Identifier parameter. I just tested this on CCX 7.0 and it works as you want it to.
Step:
Parameters:
Report Object: Resource IPCC Express
Field: State
Row Identifier: agentID (String)
Result Statistic: agentState (String)
In my test it returns Logoff, Ready, Not Ready, or Talking correctly. I suspect you get "invalid" because that is not a valid resource username.
PAUL CHEN Fri, 07/31/2009 - 15:31
Thanks for your help. It works now, because of a typo I pick the wrong row identifier.
