Which code use on a VSS system - Cisco future direction?
Jul 30th, 2009
Dear all,
we have maintained our production VSS system with 12.2.33 ... ipbasek9-vz codes, e.g.
s72033-ipservicesk9-vz.122-33.SXH2a.bin
s72033-ipservicesk9-vz.122-33.SXI.bin
s72033-ipservicesk9-vz.122-33.SXI1.bin
Now I ve stumped over the fact that these codes are from the SW download section titled "Sup720 with MSFC3" - the VSS download section does NOT offer these codes - this code here in the VSS section comes closest to the one we use:
s72033-advipservicesk9-vz.122-33.SXI1.bin
Surprisingly the last 3 ...ipservicesk9... code leves work on the VSS without noticeable problems...
However I cannot eFSU / issu upgrade from ...ipservicesk9... to ...advipservicesk9....
Now my question: This is a high availability system requiring ISSU upgrades. Might Cisco in the future give up supporting the ...ipservicesk9... code on the VSS forcing me to migrate to ...advipservices..., which requires a downtime?
Thanks and regards - Joachim
iyde Thu, 07/30/2009 - 13:02
  • Silver, 250 points or more
Hi Joachim.
I just checked the download pages for sup720-10G and found this:
s72033-ipservicesk9_wan-vz.122-33.SXI2.bin
As I see it that's what you need.
jbrauer Wed, 08/05/2009 - 06:29
Hi Ingolf,
sorry for the late reply. Thank you - yes I ve seen that image. However I have found that a family change from ipservicesk9... to ipservicesk9_wan... requires downtime (RPR upgrade). So my question is: Will Cisco in the future stop VSS support in the ipservicesk9_vz images (which are not found on the VSS sw download page).
Then I would have to go to one of the images of the VSS sw download page, needing a downtime during the upgrade.
iyde Thu, 08/06/2009 - 01:00
Hi Joachim.
I see your point. Unfortunately I do not know the answer. Hopefully some of the Cisco guys in this forum can answer?
Rgds, Ingolf
