configure ip-vpn
Jul 30th, 2009
hi friends,
i got ip connect(ip-vpn) connection from my isp etisalat.i asked my isp to provide ospf.
so, i configured ospf in my cisco router,i can able to see my neibhour routerand the state showing init/drother.
but if i try to ping from my local to etisalt isp gateway i am not able to ping.
my ospf config as follows
router ospf 1
router-id 192.168.1.6 (isp provided ip)
log-adjancies
redistribute connected subnets
network 192.168.1.0 (isp network)
network local network
can u plz help me out how i can access from my local to etisalat gateway
my gateway is 192.168.1.5.(but i can able to ping from router)
John Blakley Thu, 07/30/2009 - 07:52
  • Purple, 4500 points or more
What type of connection do you have with your provider? Can your post:
sh ip ospf neigh
sh ip route
sh run | inc ip route
HTH,
John
Peter Paluch Thu, 07/30/2009 - 09:19
  • Cisco Employee,
If you see your ISP's router in the "show ip ospf nei" as INIT/DROTHER then it means that you hear its OSPF Hello packets but it does not hear or accept your Hello packets. Are there perhaps any special requirements for setting up your OSPF given by your ISP?
Also, when looking at your OSPF configuration, I suggest removing the "redistribute connected" command. It won't solve your problem right now but you should not need to redistribute anything in OSPF - just include it using ordinary "network" commands.
Best regards,
Peter
