Initial configuration for a IDSM-2
Jul 30th, 2009
I have configured the IPS Appliance and the IPS module on ASAs... now I need to configure an IDSM-2 on a 6500.
Is it basically the same thing?
I need to configure it as an IDS first, then we will change it to IPS, so I understand that I can use SPAN to send traffic to the module, and configure the interface on the module to monitor the traffic, is this correct?
Is there anything else I should be aware of?
Thank you for any insight!
Federico.
smalkeric Wed, 08/05/2009 - 14:17
Configuration Sequence
Perform the following tasks to configure IDSM-2:
1. Configure the Catalyst 6500 series switch for command and control access to IDSM-2.
2. Log in to IDSM-2.
3. Configure the switch to send traffic to be monitored to IDSM-2.
The below URL explains about the configuration of IDSM-2 with 6500 cat switch:
http://www.cisco.com/en/US/docs/security/ips/6.1/configuration/guide/cli/cli_idsm2.html#wp1059935
4. Initialize IDSM-2.
Run the setup command to initialize IDSM-2. During setup, you can configure the interfaces of IDSM-2.
5. Create the service account.
6. Perform the other initial tasks, such as adding users, trusted hosts, and so forth.
7. Configure intrusion prevention.
8. Perform miscellaneous tasks to keep IDSM-2 running smoothly.
9. Upgrade the IPS software with new signature updates and service packs.
10. Reimage the application partition and the maintenance partition when needed.
