CAD Keypad
Jul 30th, 2009
On the Cisco CAD, users are able to input digits using the upper keys for figures 0-9 from their pc keyboard and then dial, but users can not use the actual key pad on the CAD? Nothing appears?
Derek Metcalfe Thu, 07/30/2009 - 09:24
IPCC Enterprise 7.1(2)Cisco Agent Desktop 7.1(2)(Premium Version)
If this is the bug you refer to do you know what version should be rolled out.
david.macias Thu, 07/30/2009 - 09:57
Actually I don't think this is has ever worked, for example for CTIOS you have to write that code in.
