DHCP IP lookup
Jul 30th, 2009
I am developing a vbs script that pushes a XML file to some Cisco IP phones via the HTTP post. I can always hard code IPs for testing, but is it possible to look up that IP from a centralized location each time before this message is sent? I need a way to insure that this message is sent to the correct phones. Coding example would be great. Thank You.
Mike-1985 Sun, 08/09/2009 - 22:32
Depending on your CUCM version you can use the follwoing:
CUCM version < 5; DeviceListX
CUCM version > 5; Risport -> GetDevices
Try cisco or google search for more info.
