Operate door contact closure while on a phone call
m_poublon
I have a client that is using a viking relay controller that is attached to an FXO port on the voice gateway. I have speed dials programmed on the phone that send the correct digits out the FXO port to operate the relays which unlock doors.
Everything is currently working, however, the client doesn't like that they have to put a call on hold to operate the door relays under the current config.
Is there a different way to configure this so that an on-going call is not interupted when someone needs to be let through the door(s)?
The Viking device in use is an RC-3.
paolo bevilacqua
I do not see any way to do that. Your customer should understand that the PBX keeps the call separated as expected.
paolo bevilacqua
Thanks for the reply.
I figured that would be the answer based on how I know the phone system works, but wanted to see if anyone had any ideas.
The reason that it came up was that thier old phone system was programmed with a few buttons that independantly operated the door relays without affecting any phone calls.
Thanks for the nice rating and good luck!
