CUCM Paging/Night Bell
Jul 30th, 2009
I was wondering if it is possible to have 1 extension that would ring at a 7941 and also on overhead paging horn or night bell? Has anyone done this and what would I use if possible?
Overall Rating: 5 (3 ratings)
Jonathan Schulenberg Thu, 07/30/2009 - 11:19
  • Cisco Designated VIP,
    2017 IP Telephony
As long as the night bell or other device never goes off hook, you should be able to use a shared line. If the device answers and then plays local ring back this will not work.
Rob Huffman Thu, 07/30/2009 - 11:35
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi William,
Just to add a note to the great tips from Jonathan. (+5 points for your good work here Jonathan :)
For the noise issue we use the Stinger Ringer (Model 196) from Dees Communications. You will need an Analog port off a VG or ATA (with the IP Phone Directory Number) to power this device.This thing is super loud and works well for us. Here is an excerpt from the documentation;
The Stinger Ringer cuts through the noise of any environment with a powerful 110 dBA. Its intense signal is transmitted in all directions and reaches every corner of an industrial location or home.
The Stinger 90, Model 196, operates directly from Central Office power. It has a modular plug that connects right into a standard telephone wall jack. This unit is equipped with a three position volume switch (hi - med - low).
Here is a link to the actual doc:
http://www.dees.com/html/196_198.html
Hope this helps! Start off at the lowest volume setting as this thing is LOUD!
Rob
Jonathan Schulenberg Thu, 07/30/2009 - 11:46
    2017 IP Telephony
Hey Rob-
Thanks for the easy points!
Have you ran across a ringer that also provides strobe or other lighted functionality?
Rob Huffman Thu, 07/30/2009 - 12:18
  • Hall of Fame,
    Founding Member
Hey Jonathan,
You are most welcome my friend (and your points were well deserved!) Thanks for your kind gesture as well :)
I've never found an all-in-one solution for this request always an either/or type of config. We use the Viking product line for "Strobe locations"
http://www.smarthomeusa.com/Shop/Phone/Viking-Phone-Accessories/Item/BLK-3-EWP/specifications/
http://www.algosolutions.com/pdf/AN-0703.pdf
Hope this helps! Cheers!
Rob
