Rolling over to other FXO lines
Jul 30th, 2009
I've got a UC520 with 3 analogue FXO lines.
They are all on the same single phone number, the old system it is replacing would trip over to the next line either incoming or outgoing.
This doesn't seem to be happening, we can only get one call in or out at once. I have tried swapping the lines over - they do all seem to be working.
any clues?
Adam
Steven Smith Thu, 07/30/2009 - 12:03
  • Gold, 750 points or more
The inbound calling rollover has to be done by the telco.  If the old system worked, then that is not likely the problem.
Do you have this setup as a key system?  Are you using CCA?  Can you post your config?  Remember to remove usernames and passwords from the config.
apedder123 Thu, 07/30/2009 - 13:05
Hi Steven,
Thanks for the reply.
It is set as PBX not key system. I am using CCA 2.0
I've attached a text file with the config.
Adam
Related Content
