Config files renamed
Answered Question
Jul 30th, 2009
We have this old WS-C2950T on our network that had all the flash: configuration files re-named. config.text, private-config.text, and vlan.dat, all had ".renamed" appended to the end of the file names. Has anyone seen this, and do you know what could have done it? (other than someone manually changing the names?) Thanks.
Correct Answer by Darren Ramsey about 7 years 6 months ago
This is part of the express setup. If the mode button gets pushed and held for a few seconds, then the files are renamed and the switch reboots to default. I've seen patch cables push against the mode button and this occur. Just rename the files and reload.
http://supportwiki.cisco.com/ViewWiki/index.php/Catalyst_3550_switch_reloads_and_gives_the_%22EXPRESS_SETUP-6-CONFIG_IS_RESET%22_error_message_when_the_mode_button_is_pressed_for_a_longer_time_during_a_password_recovery
Overall Rating: 5 (2 ratings)
jbrenesj Thu, 07/30/2009 - 13:34
Are normal files present and also the "renamed" files? Or only the renamed
I have never seen the vlan.dat changing its name because of any feature/process done by/to the switch
The config files could be modified by external apps like snmp or cna, it sometimes happens but I doubt the vlan database will be renamed ever
r-vaughan Thu, 07/30/2009 - 13:46
Only the ".renamed" files were present, no other config.text file was there. I suspect someone went in and renamed them, but no one will admit to it.
Leo Laohoo Thu, 07/30/2009 - 17:38
Nope. Files being renamed has to be done manually. Check your RADIUS or AAA server for any hints base on the time and date of the files.
Correct Answer
Darren Ramsey Thu, 07/30/2009 - 18:48
Peter Paluch Thu, 07/30/2009 - 21:56
Darren,
Now this is a thing... I must admit I never heard of this before but surely I will test it in the lab. Thanks you!
Best regards,
Peter
jimmysands73_2 Thu, 07/30/2009 - 22:38
I learn something all the time at a ridiculous hour that I cant sleep, good stuff.
davy.timmermans Thu, 07/30/2009 - 22:53
You can disable this feature with the following command:
no setup express
As far as I know all switches with a mode button has this feature, and enabled by default.
