WiSM upgrade failure
jasonmathew1
Hi Folks,
Running into an issue upgrading from 4.2.130 to 4.2.207, receiving the following error message and wondering if anyone has run into this same issue and if so what's the fix? Cisco TAC is telling me to reboot the C6500 chassis to resolve it...Is there any way to view what's in the flash directory on the wism?
Here's the error:
(dtc-dr5-wism1) >transfer download start
Mode............................................. TFTP
Data Type........................................ Code
TFTP Server IP................................... 10.181.87.126
TFTP Packet Timeout.............................. 6
TFTP Max Retries................................. 10
TFTP Path........................................ /
TFTP Filename.................................... SWISMK9-4-2-207-0.aes
This may take some time.
Are you sure you want to start? (y/N) y
TFTP Code transfer starting.
TFTP receive complete... extracting components.
TFTP Failure while storing in flash!
I used Tftpd32 to upload the code, any insight would be appreciated...
Lucien Avramov
Level 10
Level 10
Did you enable debugging on the WLC ?
show msglog
debug transfer
Besides reboot, other suggestions:
-increase the timeout value
-check the md5 checksum on the file on your PC and compare it with the value on our website
Leo Laohoo
Is your TFTP software able to support >32mb file? If no, try the Cisco-recommended software, TFTP32.
http://tftpd32.jounin.net/tftpd32_download.html
Hope this helps.
