Monitoring Internet Router from inside network
Jul 30th, 2009
I need help in setting this up. At the moment we are using Opmanager monitor our routers inside the network. I want to monitor our internet router sitting outside the network. Be really grate if someone can help out or point me out on how to set this up.
Paolo Bevilacqua Fri, 07/31/2009 - 01:46
  • Hall of Fame,
    Founding Member
You can use, for example, prtg.
utawakevou Tue, 08/04/2009 - 13:58
Thanks for your reply. Actually what I want is for my monitoring application sitting inside my network to monitor my internet router via SNMP. There is a FW in between
I have tried that PRTG application and its not bad. Thanks
Paolo Bevilacqua Tue, 08/04/2009 - 14:02
  • Hall of Fame,
    Founding Member
You're welcome, please remember to rate useful posts with the scrollbox below.
