"sh run" takes extremely long time to execute on cat6500
Jul 31st, 2009
I have a cat6509e and when I issue a "sh run" it takes about 4 minutes before I get any output. The cpu load is about 20 % and I don't use "service compress-config".
I have compared to other c6500 I have and on these it takes about 15 sec.
All c6500 run same IOS.
Any ideas?
Regards Kim
Giuseppe Larosa Fri, 07/31/2009 - 02:17
  • Hall of Fame,
    Founding Member
Hello Kim,
you may be hitting a bug, what IOS image is in use on the device?
On other threads a similar issue had been described.
Hope to help
Giuseppe
kholst Fri, 07/31/2009 - 02:43
Hi Guiseppe,
I'm running 12.2-18.sxf7. I have other devices running the same IOS an there I dont have the problem.
Regards Kim
