channalized Wan card(E1)
hi,
Is it possible to Channilized WIC 1T Serail Interface into 30 64 Kbps of channilized interface or subinterfce or any how is it possible?
paolo bevilacqua
No, it is not possible.
You need specific hardware for channelized service, that depends on the router you have.
5 Replies 5
paolo bevilacqua
Wilson Samuel
Level 7
Level 7
Hi Jayesh,
Just one more thing, these days we have VWIC E-1/T-1 cards, so if you are talking about any of that card, then yes, its possible. However to be absolutely sure, we will need the part number, that you may get from sh ver.
If you could paste that, then we can tell you absolutely if its possible or not.
Wilson Samuel
VWIC are not a good idea for channelized, because only 2 channel groups are supported.
The current product for channelized on ISR router are explained here:
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/product_data_sheet0900aecd80710c88.html
Wow, thanks for the update. Seems that in the last few months things have changed pretty dramatically.
So, Channelized PRI, means one can have a lot of Channel Groups configured for different things, correct?
Yes, it's some TDM technology still found in developing countries.
