err-disable state on etherchannel interface
Jul 31st, 2009
Hi all,
We've configured etherchannel on 4 interfaces. 2 interfaces are up and 2 are down.
we have the following message when trying to enable the interface:
7w3d: %PM-SP-4-ERR_DISABLE: diagnostics error detected on Gi2/43, putting Gi2/43 in err-disable state
how can i solve this problem
Wilson Samuel Fri, 07/31/2009 - 04:04
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
This usually indicates a Spanning Tree issue. Not sure if you have a looped network or not (to make sure that its fault-redundand).
What are the devices connected to it? If its a server then, probably the server is Teamed ?
In any case, if you have a PortFast Enabled on the interfaces, I guess this shows up sometime (cant recall the exact cause in my case).
Could you please paste the switch config of the concerned ports please/
regards
harinirina Mon, 08/03/2009 - 02:43
on each 4 ports and each 2 switchs, we have the following config
interface GigabitEthernet2/XX
switchport
switchport trunk native vlan 600
switchport mode trunk
no ip address
channel-group 1 mode on
2 ports are UP, the 2 others are DOWN
jbrenesj Mon, 08/03/2009 - 13:52
  • Silver, 250 points or more
Try re-seating the module.
If you reload the switch you might see diagnostic failure on the ports.
I have RMAed some WS-X6148-GE-45AF and 6548 modules do to this.
harinirina Mon, 08/03/2009 - 02:48
Hi wilson,
We've seen so many causes of %PM-SP-4-ERR_DISABLE in your document.
However, we cannot find "%PM-SP-4-ERR_DISABLE: diagnostics error detected"
if you have some url or doc concerning this, would you like to post it?
