VG200 and CM7.1?
Answered Question
Jul 31st, 2009
Hopefully a quick and easy question for someone out there?
We are planning our CM upgrade from 6.1(3) to 7.1 and want to make sure our VG200's that are currently in place are compatible.
I've looked in as many places on the Cisco site as I can think of, but can't find anything explicitly on the VG200.
Can anyone point me in the direction of a document that shows the compatibility matrix with the VG200 on, or has anyone already upgraded and has some VG200's working perfectly?
Jeff
Correct Answer by Nicholas Matthews about 7 years 11 months ago
Hi Jeff,
You can still insert the VG200 into a CM 7.x.
That being said, the code for the VG200 has not been updated in multiple years. The device is end of support, and is basically a dead box.
I wouldn't expect for anything to have changed and would expect it to work as well as it would with another CM version.
-nick
Overall Rating: 5 (1 ratings)
Correct Answer
Nicholas Matthews Fri, 07/31/2009 - 07:34
  • Red, 2250 points or more
Hi Jeff,
-nick
Jeff Clark Fri, 07/31/2009 - 07:38
Thanks Nick,
That's the answer I was hoping for!
Jeff
Ahmed Elnagar Sun, 01/03/2010 - 04:36
Hello;
Can you please tell your IOS version of your VG200...I have an upgrade from 4.1 to 6.1 and I cannot find any document that say what is the minimum version of VG200 to work with UCM 6.1.
thanks
