Collin Clark Sat, 08/01/2009 - 11:55
  • Purple, 4500 points or more
Yes you can. You will need to enable logging to the syslog server at a minimum of level 5 (notifications).
logging enable
logging host inside [syslog server ip]
logging trap 5
Hope that helps.
Hitesh Vinzoda Sun, 08/09/2009 - 04:10
  • Silver, 250 points or more
You can also integrate ACS with ASA (if you have one). Create the Username on ACS and make ASA to authenticate users on ACS.
Guillermo Soto ... Thu, 12/16/2010 - 16:39
Hi Hitesh,
     I am doing Authentication to VPN Clients on ASA (8.2(1)) to a CS ACS 5.0, but I have not been able to to the Authorization and Accounting, do you have an idea on how doing this or any URL I can reference?.  Basicly we want that when a user is logged in via VPN Client, we can also "see" waht the user is doing, which resources it is accesssing, etc
Thanks and Best Regards,
memo
