Event Connection Error on AIP-SSM-10
mkodali Wed, 08/05/2009 - 16:17
  • Cisco Employee,
What exactly are you trying to do here and where do you see this message on. Will need more details to comment.
I figured it out. There was no configuration problems on AIP-SSM itself. The problem was with the IME client application. It could not communicate with the a backend service that is installed with IME on the monitoring station. I reinstalled the client app. And everything works now. This is the first time that I have used IME. I didnt not know that there was a service in the background and assumed that it was configuration issue with AIP.
My mistake...
Thanks for the reply.
ammaralobaidi Thu, 08/05/2010 - 17:44
Hi there,
I have got the same issue here, I will try to install the new version and see if will work. However i didnt understand exactly what you meant by " It could not communicate with the a backend service that is installed with IME on the monitoring station"
can u clarify please?
ammaralobaidi Thu, 08/05/2010 - 19:34
I guess i know what u mean, The service within windows was stoped? that was my problem anyway, got it solved
thanks.
