Port Security on 2950
Answered Question
Jul 31st, 2009
I have the following setup on a port on my 2950:
interface FastEthernet0/23
switchport mode access
switchport port-security
switchport port-security mac-address 0009.4302.5614
duplex half
speed 10
I have the port-security violation shutdown enabled as well.
DAX_Rack_5#sh port-security
Secure Port MaxSecureAddr CurrentAddr SecurityViolation Security Action
(Count) (Count) (Count)
Fa0/23 132 2 0 Shutdown
Problem is, it doesnt seem to work. When I change the cable plugged in it still comes up just fine. I thought it was supposed to go ERRDISABLE or something like that?
Thoughts?
James
Correct Answer by Peter Paluch about 7 years 10 months ago
Hello James,
If I am interpreting your "show port-security" output correctly then the Fa0/23 port seems to have 132 secure MAC addresses allowed. As you have defined one static secure MAC address, there is still space for 131 secure MAC addresses. Until the space is exhausted, the switch will happily learn new MAC addresses withouth causing a security violation.
Try to add this command to your Fa0/23 configuration:
switchport port-security maximum 1
Best regards,
Peter
Overall Rating: 5 (1 ratings)
Correct Answer
Peter Paluch Fri, 07/31/2009 - 11:28
  • Cisco Employee,
Hello James,
Best regards,
Peter
jfraasch Mon, 08/03/2009 - 04:31
Dang, you are right. I had taken it off and forgot to put it back on. The 132 should have been a bit of a clue, eh!
Thanks!
