Cisco 7600 sup-bootdisk
Jul 31st, 2009
Hi all,
On a cisco 7600 rsp720 we have a RP compactflash and also a SP compactflash, how do we access RP flash and SP flash, also when we do a show sup-bootdisk what compact flash are we seeing.
Many Thanks
Jerry Ye Fri, 07/31/2009 - 11:06
  • Cisco Employee,
Hi Patricio,
sup-bootdisk: is the flash memory on the SP. The RP flash memory is bootflash:.
sup-bootdisk: is also called sup-bootflash: depend on the version of IOS you are using. You can use show file system to check out the flash memory in your SUP card.
HTH,
jerry
