Hello everyone,I have a Cisco Secure Web Appliance S300V for my company's proxy server. We have been recently directed to utilize the Signal Desktop App for communication and unfortunately I have run into every issue while getting this to work. The Q...
Hi folks recently our audit team have scanned our WSA and SMA for VApt and they have found that wsa(asyncos 14.5) and SMA (15.0) is having openssh version prior to 9.3 and should be upgraded .IS it possible to upgrade openssh alone? i searched docume...
Question, attempting to help a customer with the new S196 and we have found that the new S196 doesn't appear have the WSA-L4TM-LIC license like the old S195 did. Is this feature now included in the new Subscription license?
Thanks, Seth
Hi all,We had WSA appliance and we are migrating appliance to virtual environment.We have configured new WSA and tested and its working fine and now we are planning to move it to LIve so we are planning to change the data ip.of new virtual WSA to the...
Hi Folks i have a doubt we have Cisco data security services enabled for upload inspection in our WSA and in that policy we have one URL custom category as passthrough and one identification profile is also configured and upload limit is 500 mb .so t...
Hello,A client is trying to SSH through the HTTP proxy (WSA), it works but the response times are huge.ssh_args = -C -o "ProxyCommand=nc -X connect -x proxy-http:8080 %h %p"It serves its purpose. HTTP proxy isn't designed for that, but has anyone tri...
Anyone able to guide through a few sizing numbers for S300v/S600v/S1000v?
Currently under an incident that the 4 x S300v keeps crashing under a certain load and TAC believes it is the loading issue. However, they don't follow up with the rec...
Hi,So was reading up a lot on the difference between the Cisco Anyconnect Roaming Module vs the Umbrella Roaming,Its clear that best practice is the Cisco anyconnect option as UR is EOL in a few months, so we recently deployed the new client company ...
Is it possible to migrate policies and its dependencies alone from am SMA to another. Since both SMA are running different version backup restore is not working.
I have one question that is the number of users in the license mean the total number of WSA appliances that will apply license to them or the number of clients connected to WSA appliances, because I will use one WSA appliance in the networkLicense WS...
Hello community,inside of our network we use DNS forwardes pointed to Cisco Umbrella DNS servers.Software using these forwarders is generating events about failed PTR DNS lookups with string "DNS temporarily down".Connection to outside is managed by ...
We are migrating from our Older Cisco ASA Firewalls to Cisco FTD 2140's. We currently are using WCCP on the ASA's for Transparent Proxy with our WSA Virtual Appliance under VMWare. I was just going to migrate WCCP Configurations to the FTD 2140's w...
Hello,I don't understand how can I use transparent mode using L4 switch (it's load-balancer, right?). I'm friendly with L4 switches, even though I can not imagine the topology and data flow. I have two WSA boxes and I need configure active-backup mod...
Hi, currently we are using umbrella roaming clients across 3000 roaming user laptops. Now we need to upgrade the client to Cisco Secure Client.How the bulk upgrades can be done across roaming user laptops
