VPLS on 12000 series IOS
Giuseppe Larosa Sat, 08/01/2009 - 05:23
Hello Pramod,
GSR 12000 and ASR 1000 are routers:
commands have to applied to:
main interfaces or subinterfaces there are no SVIs here only L3 interfaces and subinterfaces.
Hope to help
Giuseppe
marikakis Mon, 08/03/2009 - 08:13
An 'xconnect' command is not used when configuring VPLS on the GSR. Please have a look at the following document about configuring VPLS on the GSR:
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/vpls_qos.html#wp1038114
Also, you should probably have a look at the limitations/restrictions:
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/vpls_qos.html#wp1025005
and the supported ISE linecards and SPAs:
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/vpls_qos.html#wp1025011
The limitations/restrictions are plenty, so you probably need to test and/or contact cisco to address the requirements of your specific environment.
p.s. I can't help with the ASR 1000, but I think somebody replied to another conversation that you opened about this platform.
