Robert.N.Barrett_2 Sat, 08/01/2009 - 05:08
I don't believe you can upgrade your existing hardware. You may be able to arrange a trade-in, though.
You could always get another 4402-12 and put them in the same mobility group.
George Stefanick Sat, 08/01/2009 - 05:31
You can not upgrade the 4402-12 appliance to handle additional access points above the 12. The 12 is hard set.
The new 5500's are going to be allow different ap counts via a license.
n.vd.coevering Sat, 08/01/2009 - 08:31
OK, thanks. Then hopefuly there is a trade-in possiblity. Adding another 4402-12 is more expensive.
Lucien Avramov Sat, 08/01/2009 - 13:01
The 2106 lets you add another 6 AP and should be less expensive than the 4402-12. You may be able to trade it in if it's within 90 days, check with your account team.
Depending on what design you have you might also consider autonomous access-points.
Leo Laohoo Sat, 08/01/2009 - 18:16
Don't worry. You can ideally use the WLC4402-12 in a lab environment.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
