CM on dl320
Aug 1st, 2009
I am learning VOIP and truing to set up a lab , I found this server and I would like to install CM, my question is
can I do that ?
what CM Ver. do I need ?
what os needed to be install on dl320 before I install CM ?
any wite paper or how too for this platform ?
THanks
HP Proliant DL320 G2 Server
2.66 Xeon Processor
2x 80GB Harddrives (Can do raid 1 or 0)
4GB RAM
Rackmountable 1U form factor
Overall Rating: 4 (1 ratings)
Jaime Valencia Sat, 08/01/2009 - 15:17
  • Cisco Employee,
  • Hall of Fame,
    2011
This link contains the list of supported platforms
Supported Cisco Unified Communications Manager Releases by Server
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
What version you need depends on what you can get your hands on, i'd recommend at least 6.1(x), preferably 7.x but your server does not meet the 3 GHz requirement
OS is installed with CUCM, Windows version were a separate OS install from CCM.
Install is rather simple, load DVD and fill in the blanks. If you want to read something before, refer to install guides available on CCO
java
if this helps, please rate
cisco steps Sun, 08/02/2009 - 06:58
I am just going to stay w/ cisco equip for now. as newbie to the voice world. any idea for cheap routers that will support CM I know I need to get some type of voice gtwy to create the real scenario ..
THanks
