dl320
Aug 1st, 2009
I am learning VOIP and truing to set up a lab , I found this server and I would like to install CM, my question is
can I do that ?
what CM Ver. do I need ?
what os needed to be install on dl320 before I install CM ?
any wite paper or how too for this platform ?
THanks
HP Proliant DL320 G2 Server
2.66 Xeon Processor
2x 80GB Harddrives (Can do raid 1 or 0)
4GB RAM
Overall Rating: 4 (1 ratings)
Rob Huffman Sat, 08/01/2009 - 11:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi OC,
This is the "master" list for Server support, which does show support for your box up to CUCM 6.1(x);
Supported Cisco Unified Communications Manager Releases by Server
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
You may want to use this on VmWare for your lab as well. If you are building a 6.x version of CUCM on this box the underlying Linux OS will be installed during the install;
Cisco Unified Communications Manager 6.0 SDK.
Part#: CM6.0-K9-SDK=
The Cisco Unified Communications Manager 6.0 SDK is a developer version of Unified Communications Manager made available strictly for development and test use only - not for production use. The software comes with a 50-DLU license and must be installed for use on a computer running the VMWare Player, which is available as a free download.
The Cisco Unified Communications Manager 6.0 SDK is a developer version of Unified Communications Manager made available strictly for development and test use only - not for production use. This software is available to all developers interested in creating applications for the Cisco Unified Communications system of voice, video, and IP communications products. The software comes with a 50-DLU license and must be installed for use on a computer running the VMWare Player, which is available as a free download.
https://cisco.mediuscorp.com/market/callmanager/productView.se.work;jsessionid=7030801ef9d5$C4$FD$C?/nxt/rcrs/proieidentity/=16340
To purchase this developer version of Cisco Unified Communications Manager 6.0, please use the link below to go to the Cisco Marketplace page for this SDK product. You will need a credit card to purchase this product.
Cisco Marketplace
http://www.cisco.com/web/developer/cucm/content/download.html
Hope this helps!
Rob
cisco steps Sun, 08/02/2009 - 06:58
I am just going to stay w/ cisco equip for now. as newbie to the voice world. any idea for cheap routers that will support CM I know I need to get some type of voice gtwy to create the real scenario ..
THanks
