Reasons for Login Failed to NAC in L3OOB
Aug 1st, 2009
I am implementing NAC in L3OOB envirnment, setup is upgradeed to 4.5, my NAC expertise is best effort.
I assumed I have finished building the basic setup to test authenticating CCA agent using local DB, but on entering user credential to the pop-up, I get "Login Failed" with no identified reason.
I just wonder if there is a link to a document shows the mandatory steps must be done before assuming NAC solution is ready for testing.
Definite, it would be grateful if you have a hint what could be the reason for login failure.
