Source Based ROuting
Aug 2nd, 2009
Hii,
Kindly tell me about IP source based routing in cisco (router/L3 switches). How to check the status of IP source based routing on router (if enabled or diabled).
PLease share the command to disable IP SOURCE based routing on cisco device.
ivarnhagen Sun, 08/02/2009 - 02:34
you can find information about policy routing (routing based on configured policies, incl. source IP) here:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009481d.shtml
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpbr_ps1835_TSD_Products_Configuration_Guide_Chapter.html
http://www.petri.co.il/how-to-use-cisco-ios-policy-based-routing-features.htm
PBR is not configured by default. To disable an existing PBR configuration, remove the route map from the interface. To keep the config clean, you would also want to remove the other related commands.
Please rate if this helps.
Paolo Bevilacqua Sun, 08/02/2009 - 02:37
  • Hall of Fame,
    Founding Member
no ip source-route
