The discovery takes long time in LMS3.1
Aug 2nd, 2009
we have LMS3.1 CS3.2m the discovery takes more than 4 hr, in the old setup LMS2.6 took 1hr only
I used only cdp protocol with DCR as seed devices.
please find below the configuration of discovery as shown in the summary :
Module Settings
Module(s) Selected: CDP
Seed Device Settings
Module Seed Device File Use DCR As Seed Seed Devices [Hop Count / Subnet Mask*]
CDP Yes
*Subnet Mask is applicable only for 'Ping Sweep On IP Range' module
Global Seed Device Settings:
Seed Devices:
Seed Device File:
Use DCR As Seed: Yes
SNMP Settings
Version User Name Auth Algorithm Priv Algorithm Timeout Retry Target
v2c 2 2 10.*.*.*
v2c 2 2 172.*.*.*
v2c 1 2 10.*.*.*
v2c 1 2 172.*.*.*
Note: User Name, Auth Algorithm and Priv Algorithms are not applicable for SNMP versions v1 and v2c
Filter Settings
Filter Type: IP Address
Filters(include) : 10.*.*.*, 172.*.*.*,
Global Settings
Preferred DCR Display Name: FQDN
Preferred Management IP: Use LoopBack Address
Update DCR Display Name: Yes
Use Default Credentials: Yes
ICMP Timeout: 1000
ICMP Retry: 1
InterPacket Timeout: 20
Email:
Add Discovered Devices to a Group: No
Selected Group Name:
Overall Rating: 5 (1 ratings)
Joe Clarke Sun, 08/02/2009 - 09:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
These settings look good. I suggest you contact TAC to have them walk you through enabling CSDiscovery debugging and analyze the ngdiscovery.log to see where the time is being spent. Typically we see problems due to high timeouts or retries. That may still be a factor here, but your values are probably low enough to avoid huge delays.
Joe Clarke Mon, 10/12/2009 - 05:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
As I said, I see no problems in your settings. You should open a TAC service request so additional debugging can be enabled, and Discovery can be analyzed as it runs. My initial thought on why it may be taking a long time is that you're using a sysObjectID filter. This means that Discovery must contact every device it finds with SNMP before it can apply any filtering. If the device is not SNMP reachable with the given community strings, you will encounter delays. If you want to try and rule that problem out, consider applying an IP address filter instead.
Martin Ermel Mon, 10/12/2009 - 09:15
  • Blue, 1500 points or more
have you also checked the settings for your scheduled discovery jobs in
Common Services > Device and Credentials > Device Discovery > Discovery Scheduled
Martin Ermel Mon, 10/12/2009 - 23:12
I meant if you have checked the settings for scheduled discovery job and not only for adhoc discovery?
Adhoc discovery settings are
Common Services > Device and Credentials > Device Discovery > Discovery Settings
(these are the settings used for an adhoc discovery job when clicking on "Start Discovery" ond the "Device Discovery" page)
Each scheduled discovery job does have its own settings when you go to
Common Service > Device and Credentials > Device Discovery > Discovery Schedule
mark the job and click "Edit Settings". These settings can be completely different from the before mentioned
If you create a NEW scheduled discovery job, the current settings from the adhoc discovery are used for this job (and can later be changed by going through "Edit Settings" for each job).
