Bulk Edit not changing TUI password correctly
I have Unity 5.0 Build 5.0(1) and bulk edit 4.0 build 115.
When I use the password tab to reset a range of users passwords they are not changed correctly. I have set a users password to a default of 2222 using SA and verified it was correct by logging in via the TUI. I then ran the bulk edit tool and changed this users password to 3333. Now neither password works.
Any suggestions?
Overall Rating: 5 (1 ratings)
Hoan Mai Tue, 08/11/2009 - 13:55
  • Cisco Employee,
Tom,
you might be hitting this defect -
CSCsr02403 Using BulkEdit tool to change password results in blank password
Symptoms:
Password is blank after changing it via BulkEdit tool
Conditions:
This problem may occur in Unity 4.2(1) and Unity 5.0(1).
The issue is fixed in Unity 7.0(2) and later.
Workaround:
You can manually set the password via SAWeb
Or, to use Bulk Edit but avoid the defect, perform the following before running Bulk Edit.
Open a command prompt (DOS) and go to \CommServer\components
The type in the following commands;
Regsvr32 /u BabelSvr.dll
Regsvr32 BabelSvr.dll
