Plz Help in VPN C
alsayed
Hello
I Have Connected the RS Straight Through cable with 2 DB 9 Female to both end PC/Console and VPN Concentrator 3005 with the following settings as described in cisco document ….I've attached image for cables that I use
• Bits per sec: 9600
• Data bits: 8
• Parity: none
• Stop bits: 1
• Flow control: Hardware
But the nothing appears on the console even the garbage not exist either
What's the Problem? How can I overcome on this issue
JORGE RODRIGUEZ
Level 10
Level 10
Are the DB9s real RS232 ? if so fine, is the cable straight through CAT5 ? perhaps try another cat5 cable, if cable is fine then next would be are you usign correct COM1 or whatever COM port the system is using? have you try using
another system ?
regards
Jorge Rodriguez
Hello
What do y mean by """Are the DB9s real RS232"""...i m using the rs cable came with the concentrator
thanks
ttran
Hello
I would check the 2 DB9s are from Cisco. If the RS cable still not work, try with the straight-through RJ-45 Ethernet cable.
hi
how can console to VPNC Using straight-through RJ-45 Ethernet cable>is that possible?
10xs
