08-02-2009 02:54 PM - edited 03-06-2019 07:03 AM
1. If you go to the 87X download page, the ROMmon is classified as "C85x/C87x ROMMON Upgrade" but the file(s) are not available in the 85X download page. Is it or is it not the file valid for the C85x/C87x routers?
2. I'm trying to investigate the 12.3(8r)YI6 ROMmon but I can't download the file. Is the link broken?
Thanks.
Solved! Go to Solution.
08-02-2009 05:07 PM
Leo,
Most of the tools for searching this type of query are unavailable at this moment but based on a filename and bug description on the reason this was released, I believe it's only intended for the 87x hardware and the download description is wrong.
HTH,
__
Edison.
08-03-2009 05:29 AM
Leo,
I was able to confirm this was indeed a bug download description error as the rommon upgrade addresses a bug that only affects the 87x series
HTH,
__
Edison.
08-02-2009 03:04 PM
There is a maintenance window taking place at this moment, try again within 12 to 24hrs.
__
Edison.
08-05-2009 06:55 PM
Hi Edison,
"maintenance window" or a failed network change due to "human error"? He he he ...
08-02-2009 04:01 PM
Hi Edison,
Thanks for the quick response (+5).
How about my first question?
08-02-2009 05:07 PM
Leo,
HTH,
__
Edison.
08-02-2009 06:55 PM
Hi Edison,
Thanks for the response.
08-03-2009 05:29 AM
Leo,
HTH,
__
Edison.
08-03-2009 01:51 PM
Thanks Edison. I've sent a number of feedbacks about the accuracy of the description but I guess everyone is very busy there. :)
