IP Communiator issue in the VPN network
Aug 2nd, 2009
I Installed IP Communicator in the One of the laptop who having the VPN network access also. But now we are facing one problem. They can only make internal calls after connecting vpn network. But if they trying to reach PSTN network they are getting busy tone.
Is there any issue any related to Firewall or any other stuffs. Once user is using this things in to the Local Lan its working fine.
Sunish
timurbayazitov Mon, 08/03/2009 - 00:36
Sunish, it seems to be a routing issue.
So you should first check for ip routes received from VPN server using "route print" windows CLI command and whether these routes are affecting path to voice gateways and so forth.
Hope these helps.
