about certificates for use with WebVPN on Cisco ASA 8
Aug 2nd, 2009
I am in the process of purchasing certificates which would allows me to have 6 domains ( with 1 domain as primrary and 5 domains as SAN( subject alternative name)...
I want to make sure that the certificate would support the Cisco ASA with webVPN...
I have enquire entrust which has a certificate called Advantage SSL certificate which is compatible with Cisco ASA.. however, it only holds 2 domain name maximum..
http://www.entrust.net/cisco/
Any idea where can I purchase a certificate that would support web VPN on Cisco ASA 8 and allows up to 6 domains name in the certificate please?
kind regards
Rachel
