LDAP group lookup does not work well from ACS
Aug 2nd, 2009
Dear Friends,
We are planning for a solution that requires ACS to do an LDAP query into the LDAP database.
The lookup is basically for user groups in LDAP. We also have a local ACS group configured with the same name. When we try to do a Database group mapping, it fails. The user is logging into the network via dial-up. His user should be in that specific ACS group but he is being put in Default Group. So, my problem is that database group mapping is not working.
We have ensured that the group is in the same case sensitive format as the LDAP
group.
Any suggestions please
Thanks and Regards
Gautam
gautamzone Mon, 08/03/2009 - 00:31
Let me share with you the LDAP configuration.
User Directory Subtree:
cn=users,dc=x,dc=y,dc=edu
Group Directory Subtree:
cn=groups,dc=x,dc=y,dc=edu
User Object Type: uid
User Object Class: Person
Group Object Type: cn
Group Object Class: posixGroup
Group Attribute Name: memberUID
We are using LDAP v3 and its working.
Thanks and Regards
Gautam
