Number of CPUs for a LMS for 5000 devices
Answered Question
Aug 2nd, 2009
we have to install a LMS 3.1 for 5000 devices in a Windows server. In hardware requirements, it says that we need 4 CPU's for this kind of installation.
My question is: can we use only 2 CPUs if we use Quad Core processors?
Many thanks.
Correct Answer by Joe Clarke about 7 years 10 months ago
Yes, this meets the MINIMUM requirements for running all LMS applications on a single server managing 5000 devices. Just be aware, that sometimes the minimum requirements don't provide the best performance. Where you can improve things is with more RAM, and more CPU speed.
Overall Rating: 5 (2 ratings)
Joe Clarke Sun, 08/02/2009 - 23:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, if the CPUs are truly multi-core (and not just Hyperthreaded), then that will be fine. Fir this configuration, you will need Windows 2003 Enterprise Edition (with PAE enabled) with the 4 CPUs (i.e. 4 cores) and 8 GB of physical RAM.
cmartinvalle Mon, 08/03/2009 - 00:02
So we configuration should be:
- 2 CPUs Quad Core (multi-core).
- Windows 2003 Server Enterprise Edition with PAE enabled.
- 8 Gb of physical RAM.
Could you confirm if this is correct?
Many thanks.
Correct Answer
Joe Clarke Mon, 08/03/2009 - 08:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
