Conference Question
Hi Netpro's
I have a UCM 7 system with 2 central servers. All 7 remote sites break out of the PSTN when making calls to other sites.
My problem is this, we have a meetme number of 1900 which is a member of one partition that is allocated to our central site.
How can I make our other sites access the 1900 via our WAN so that all remote users can use the 1900 number for conferencing??
As we don't have QOS on our network Its important that all (except for 1900 conference number) pass over the PSTN.
do I need to create a seperate partiton and CSS? or am i barking up the wrong tree.
Thanks in advance
Rod
Jaime Valencia Mon, 08/03/2009 - 06:19
  • Cisco Employee,
  • Hall of Fame,
    2011
Yes, that's correct.
If you only want calls to the meet-me DN to traverse the WAN create a separate partition and make sure that's the only one everyone can reach.
java
if this helps, please rate
