08-03-2009 04:40 AM - edited 03-15-2019 07:11 PM
Hi i have severals cisco i phone 7920 I can make then get connecte to my wifi so I wonder if there is a compatibility list of access point we can use with the cisco ip phone.
Thank you very much
08-03-2009 08:02 AM
Hi i have severals cisco i phone 7920 I can not make then get connected to my wifi, so I wonder if there is a compatibility list of access point we can use with the cisco ip phone. I do not have cisco aeronet
Thank you very much
08-19-2009 02:15 AM
It is solved now
08-20-2009 07:12 AM
Hi everyone.
I thouth my problem was solved. This is not the case.
Indeed I think there is problem with the firmware.
I have a 7920 with a firmware 7920.4.0-02-02-002. I was able connect it to a netopia using wep and to an airport use WPA.
I have a 7920 with a firmware 7920.4.0-03-02 I does not get connected any where.
Does Any body knows about this issue?
