Dual T1 Point to Point Configuration on Cisco 2610
Aug 3rd, 2009
Greetings,
I was wondering if anyone out there can help me with a supposed to be "very simple" Point to Point MLPPP router configuration. Currently we have two of our branches connected using one P2P T1 provided by AT&T, and now we have installed two new T1 lines provided by TDS to replace the AT&T T1.
We are planning to bundle two new T1 line provided by TDS to increase the bandwidth within branches.
The scenario is that, all the interfaces show that they are up and active but no packet goes across. Also, when I manually shutdown one interface on one side router logically on the other end interface should go down too but that is not happening.
I have attached both routers configuration below:
Main_to_Ells#show config
Using 1409 out of 29688 bytes
version 12.3
hostname Main_to_Ells
boot-start-marker
boot-end-marker
enable secret 5 $1$67dJ$r2sWrP4OIBn9rjH4U/3ln1
enable password ********
clock timezone ES -5
no aaa new-model
ip subnet-zero
ip cef
ip name-server 10.31.1.180
no ip bootp server
controller T1 0/0
framing esf
clock source line primary
linecode b8zs
channel-group 1 timeslots 1-24 speed 64
controller T1 0/1
framing esf
linecode b8zs
interface Multilink1
ip address 10.31.100.22 255.255.255.252
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
interface Ethernet0/0
description connected to local subnet 10.31.1.X
ip address 10.31.1.2 255.255.255.0
ip route-cache flow
full-duplex
interface Serial0/0:1
no ip address
encapsulation ppp
ip route-cache flow
tx-ring-limit 26
tx-queue-limit 26
no fair-queue
ppp multilink
interface Serial0/1:1
no ip address
encapsulation ppp
ip route-cache flow
tx-ring-limit 26
tx-queue-limit 26
no keepalive
no fair-queue
ppp multilink
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 10.31.1.1
ip route 10.31.6.0 255.255.255.0 10.31.100.21
line con 0
login
line aux 0
line vty 0 4
password *******
login
end
version 12.3
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
no ip bootp server
controller T1 0/0
framing esf
linecode b8zs
controller T1 0/1
framing esf
linecode b8zs
ppp multilink
ip route-cache flow
full-duplex
no ip address
encapsulation ppp
ip route-cache flow
tx-ring-limit 26
tx-queue-limit 26
no fair-queue
ppp multilink
no ip address
encapsulation ppp
ip route-cache flow
tx-ring-limit 26
tx-queue-limit 26
no keepalive
no fair-queue
ppp multilink
no ip http server
ip classless
line con 0
login
line aux 0
line vty 0 4
login
end
John Blakley Mon, 08/03/2009 - 09:53
  • Purple, 4500 points or more
Your post shows the config for the same router twice. Can you post the other side's config?
HTH,
John
eweber1234 Mon, 08/03/2009 - 10:39
Opps... here you go the second router configuration thank for looking into this matter:
Ellsworth-R#show config
Using 1458 out of 29688 bytes
version 12.3
hostname Ellsworth-R
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
no ip bootp server
controller T1 0/0
framing esf
linecode b8zs
controller T1 0/1
framing esf
linecode b8zs
ip address 10.31.100.21 255.255.255.252
ppp multilink
ip address 10.31.6.2 255.255.255.0
ip route-cache flow
full-duplex
no ip address
encapsulation ppp
ip route-cache flow
tx-ring-limit 26
tx-queue-limit 26
no keepalive
no fair-queue
ppp multilink
no ip address
encapsulation ppp
ip route-cache flow
tx-ring-limit 26
tx-queue-limit 26
no keepalive
no fair-queue
ppp multilink
no ip http server
ip classless
ip route 0.0.0.0 255.255.255.0 10.31.100.22
access-list 100 permit ip any any dscp cs7
access-list 101 permit ip any any dscp cs6
priority-list 1 protocol ip high list 100
line con 0
login
line aux 0
line vty 0 4
exec-timeout 30 0
login
end
Ellsworth-R#
---------------Ellsworth-R#show ver
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 15:23 by dchih
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Ellsworth-R uptime is 2 days, 15 hours, 24 minutes
System image file is "flash:c2600-i-mz.123-26.bin"
cisco 2610 (MPC860) processor (revision 0x202) with 28672K/4096K bytes of memory
Processor board ID JAD03341259 (683390826)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
2 Channelized T1/PRI port(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
John Blakley Mon, 08/03/2009 - 10:49
I agree with what the previous poster put. Put the "keepalive" option back on the interfaces for the time being. With "no keepalive" the interfaces don't send keepalive packets, and it makes it look like the interface is always up.
Secondly, also as the other poster mentioned, the provider has to provision your circuit for multilink in order for multilink to work. I had this problem at one point to.
Thirdly, can you ping any of the following:
10.31.1.1 from Main_to_Ells
10.31.100.21 from Main_to_Ells
10.31.100.22 from Ellsworth
Also, you could post the output from "sho controll t1" and we can see if you have any errors.
Can you also post "sh int | inc CRC|line"
HTH,
John
eweber1234 Mon, 08/03/2009 - 11:15
Thanks for your imputs
here the result of pings:
Main_to_Ells#ping 10.31.1.1
Sending 5, 100-byte ICMP Echos to 10.31.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Main_to_Ells#ping 10.31.100.21
Sending 5, 100-byte ICMP Echos to 10.31.100.21, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Main_to_Ells#ping 10.31.100.22
Sending 5, 100-byte ICMP Echos to 10.31.100.22, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/8/8 ms
Main_to_Ells#
Main_to_Ells#sh int | inc CRC|line
Ethernet0/0 is up, line protocol is up
98 input errors, 98 CRC, 49 frame, 0 overrun, 0 ignored
Serial0/0:1 is up, line protocol is up
2160 input errors, 676 CRC, 1468 frame, 0 overrun, 2 ignored, 16 abort
Serial0/1:1 is up, line protocol is up
71782 input errors, 4583 CRC, 32857 frame, 0 overrun, 62 ignored, 34342 abort
Multilink1 is up, line protocol is up
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
Main_to_Ells#
------------ on the second router
Ellsworth-R#sh int | inc CRC|line
4 input errors, 4 CRC, 0 frame, 0 overrun, 0 ignored
33145699 input errors, 1081539 CRC, 32064154 frame, 0 overrun, 198 ignored,
6 abort
32925807 input errors, 1030437 CRC, 31895364 frame, 0 overrun, 217 ignored,
6 abort
87 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
Ellsworth-R#
Also, I'm on the phone with TDS to make sure that the T1s are provisioned properly
Thank you very much,
slmansfield Mon, 08/03/2009 - 09:55
  • Silver, 250 points or more
It looks like you have "no keepalive" set on the s0/1:1 interfaces on both sides. With this setting it will look like the interface is UP UP when it may not be.
Other than that, I'd check with the Service Provider to ensure that the circuits are configured for MLPPP. We ran into some issues where the carrier did not order the circuits for this purpose.
eweber1234 Mon, 08/03/2009 - 10:49
Is this how it supposed to be?
Hardware is AmdP2, address is 0007.856c.4d40 (bia 0007.856c.4d40)
Description: connected to local subnet 10.31.1.X
Internet address is 10.31.1.2/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/2/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 6000 bits/sec, 9 packets/sec
5 minute output rate 0 bits/sec, 1 packets/sec
1978713 packets input, 162893269 bytes, 0 no buffer
Received 1966803 broadcasts, 0 runts, 0 giants, 0 throttles
42478 packets output, 4343603 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 lost carrier, 0 no carrier
Hardware is PowerQUICC Serial
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
Encapsulation PPP, LCP Open, multilink Open, loopback not set
Keepalive set (60 sec)
Last input 00:01:14, output 00:00:04, output hang never
Last clearing of "show interface" counters 3d01h
29297 packets input, 1287902 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 4 giants, 0 throttles
29306 packets output, 1287776 bytes, 0 underruns
0 output errors, 0 collisions, 13 interface resets
9 carrier transitions
Timeslot(s) Used:1-24, SCC: 1, Transmitter delay is 0 flags
Last input 00:00:19, output 00:00:09, output hang never
29299 packets input, 1287630 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 1 giants, 0 throttles
29301 packets output, 1288034 bytes, 0 underruns
Timeslot(s) Used:1-24, SCC: 2, Transmitter delay is 0 flags
Not working yet though !!!
Thanks for any help,
John Blakley Mon, 08/03/2009 - 10:54
You have a lot of CRC errors on both links. This is usually due to the clock source. Your clock source should (most of the time) be set to line if you're getting timing from the provider.
Post "sho controllers t1" and we can tell what it's clock source is.
John
eweber1234 Mon, 08/03/2009 - 11:23
here are the results for both routers:
Main_to_Ells#sh controllers t1
T1 0/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20070320, FPGA: 20, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line Primary.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (267 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
T1 0/1 is up.
No alarms detected.
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
Data in current interval (268 seconds elapsed):
Main_to_Ells#
Ellsworth-R#sh controllers t1
T1 0/0 is up.
No alarms detected.
Data in current interval (36 seconds elapsed):
0 Line Code Violations, 439 Path Code Violations
1 Errored Secs, 1 Bursty Err Secs, 9 Severely Err Secs, 0 Unavail Secs
55 Line Code Violations, 962763 Path Code Violations,
882 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 950 Degraded Mins,
2411 Errored Secs, 1799 Bursty Err Secs, 17178 Severely Err Secs, 0 Unavail
Secs
T1 0/1 is up.
No alarms detected.
Data in current interval (39 seconds elapsed):
0 Line Code Violations, 401 Path Code Violations
35 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
30 Errored Secs, 1 Bursty Err Secs, 7 Severely Err Secs, 0 Unavail Secs
35 Line Code Violations, 960752 Path Code Violations,
79031 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 927 Degraded Mins,
63173 Errored Secs, 1605 Bursty Err Secs, 17203 Severely Err Secs, 0 Unavai
l Secs
Ellsworth-R#
slmansfield Mon, 08/03/2009 - 12:05
The output of Show Controllers shows massive Path Code Violations incrementing on the Ellsworth circuits. I'd clear counters and monitor them, check physical connectivity, then verify the configuration with my carrier. Have the carrier test both circuits.
