where to edit OS79XX.TXT
cfajardo1_2
From the below quote from cisco to convert sip to sccp 7960, where cani find and edit the file OS79XX.TXT?
____________________________________
SIP Images 4.x/Earlier to SCCP Images 6.x/Later
If your current SIP images is 4.x or earlier, complete these steps in order to convert to the desired SCCP images 6.x or later:
Complete these steps in order to convert to the 6.3 image first:
Copy the desired binary image from Cisco.com to the root directory of the TFTP server.
Open the OS79XX.TXT file with a text editor and edit the file to include the desired image.
Specify the desired image in the protocol configuration files.
Reset each phone.
5 Replies 5
paolo bevilacqua
You don't need to do that.
Reset phone via long # at powerup, then 123456789*0#
Phone will look for term70.default.loads and associated files, make sure you have them on the CME router and configured tftp-server.
iam using cm6..
ive tried doing that but i couldnt see a flasshing mute,speaker and headset..
iam using cm6..
In OS79XX.TXT just put the image filename without extensions.
sorry but i dont know where to get this txt file
