Unknown phone messages
Aug 3rd, 2009
I'm having the following problem.
Unknown phone messages being routed to Domino accoount EAdmin35cf39ee. You can hear someone talking and then there is a pause and then the person talking again.
Overall Rating: 5 (1 ratings)
Tommer Catlin Mon, 08/03/2009 - 10:55
  • Green, 3000 points or more
Messages will go to the EAadmin account when it cant be delivered for some reason. Unity will record the voicemail and is supposed to route it to the person it was intended for. If it cant, it will dump it in the Admin box for sorting. This could have came from a call handler that had "record greeting" after the message, or a broken subscriber mailbox.
Possibly run dbwalker and look for broken links in the database if you are getting a lot of these messages.
j.mccartney Wed, 08/05/2009 - 06:24
Can you run dbwalker during the day without impact to users or is this usually an after-hours type of maint issue? Thanks.
Tommer Catlin Wed, 08/05/2009 - 06:26
id make a dirt backup, then run dbwalker. Both I would do after hours.
Christopher McAlpin Wed, 08/12/2009 - 10:33
  • Cisco Employee,
By default, the default Operator Call Handlers "Closed" greeting after greeting action is set to send the caller to the Example Interview Handler. The Example Interview Handlers message recipient is the Example Administrator account.
