PIX with SNMP
Answered Question
Aug 3rd, 2009
I have a PIX 515 version 6.3 software.
I use What's UP Gold for some basic network monitoring. What I really want to keep an eye on for the PIX is
sho connections
How do I do that with SNMP? I can't seem to find it in the MIB at all...and does Cisco offer any sort of software to make monitoring the PIX (CPU, Memory, Connections, etc) nice and easy?
Thank you.
Correct Answer by Collin Clark about 7 years 11 months ago
Chief-
No easy way, just have to use the MIBs. Hope these help.
PIX/ASA/FWSM
System: 1.3.6.1.2.1.1
Interfaces: 1.3.6.1.2.1.2
IP: 1.3.6.1.2.1.4
Memory: 1.3.6.1.2.1.4.1.9.9.48
CPU: 1.3.6.1.2.1.4.1.9.9.109
Firewall: 1.3.6.1.2.1.4.1.9.9.147
Buffers: 1.3.6.1.2.1.4.1.9.9.147.1.2.2.1
Connections: 1.3.6.1.2.1.4.1.9.9.147.1.2.2.2
SSL Stats: 1.3.6.1.4.1.3076.2.2.26
IPSec Stats: 1.3.6.1.2.1.4.1.9.9.171
Remote Access Stats: 1.3.6.1.2.1.4.1.9.9.392
FIPS Stats: 1.3.6.1.2.1.4.1.9.9.999999
Active Connections in PIX/ASA Firewall: 1.3.6.1.4.1.9.9.147.1.2.2.2.1.5.40.7
The total number of currently active IPsec Phase-2 Tunnels: 1.3.6.1.4.1.9.9.171.1.3.1.1.0
You will need the following MIBs: IF-MIB, RFC1213-MIB, CISCO-MEMORY-POOLMIB, CISCO-PROCESS-MIB, ENTITY-MIB, CISCO-SMI, CISCO-FIREWALL-MIB, ASA also adds CISCO-IPSEC-FLOW-MONITOR-MIB, CISCO-FIPS-STAT-MIB, and ALTIGA-SSL-STATS-MIB.
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Mon, 08/03/2009 - 11:43
  • Purple, 4500 points or more
Chief-
PIX/ASA/FWSM
IP: 1.3.6.1.2.1.4
GRANT GATHAGAN Mon, 08/03/2009 - 16:03
Take a look at FireGen reporter for PIX from Altair Technology.
It's not the most intuitive piece of software that I've ever set up, but it does a good job in analyzing syslog files.
It wouldn't be a real-time monitor, but you could probably set it up to generate reports as frequently as you desire.
http://www.altairtech.ca/
